kz1300 banner
water pump bevel drive gear wanted HELP!!
  • geofie
  • geofie's Avatar Topic Author
  • New Member
  • New Member
9 years 11 months ago
#9346
Cannot believe this gear was damaged,and in more disbelief that they are hard to get.can anybody help.I think the part number is 49022-1015
  • Lucien-Harpress
  • Lucien-Harpress's Avatar
Re: water pump bevel drive gear wanted HELP!!
#9348
Let me check. Nearly 100% positive I have something.
  • kwak1261
  • kwak1261's Avatar
#9349
In stock at the Germans
www.z1300.de/
Z1300 A4 ZG1300 DFI X2
Z1261J GS1000S
Vmax1200 XT500
  • Tyler
  • Tyler's Avatar
  • Elite Member
  • Elite Member
#9350
Yup the German shop it the only option for a new one, usually the water pump gear failure is the result of overheating. (and then of coarse the cause of overheating).
Might be time to do your water pump seal and the small oil seal on the water pump drive shaft too. They are pretty inexpensive insurance considering the work to get to those parts in the future.
1981 KZ1300
  • strate6
  • strate6's Avatar
  • On An Adventure Before Dementia ! !
#9351
Be aware there are 2 types of water pump bevel gear for 1300's.
One is fitted to the A1 & A2 (with pick ups behind the cylinders) and the other for every other model A3 onwards (pick ups on end of crank).
You can use either of them on all models A3 onwards but the A1 & A2 must be from the A1 & A2........as they have the splined drive added for the pick ups.
Water Pump Drive Gears normally only fail if your bike gets too hot or is low on oil and the nylon gets soft and fails.
I have tried the German reconditioned type and had numerous failures as many others have here in the UK.
Pete F
  • Tyler
  • Tyler's Avatar
  • Elite Member
  • Elite Member
9 years 11 months ago - 9 years 11 months ago
#9352
Strate6 its right, I found that you can put an earlier gear on the later style biKes, but you cannot run the later style on the '79 and '80 bikes. I put a used gear from a '79 in my bike (81) when I redid the top end.
So it is advisable to find a used gear in good condition before buying the reproduction part?
1981 KZ1300
Last edit: 9 years 11 months ago by Tyler.
Time to create page: 0.179 seconds
