kz1300 banner
Replacement fuel tap
  • Bucko
  • Bucko's Avatar
Re: Replacement fuel tap
7 years 4 months ago - 7 years 4 months ago
#19746
The auto fuel shutoff valves on my Hondas use only one hose. On the Hondas, the vacuum diaphragm works against a spring; when the motor turns off the manifold vacuum drops to zero and spring closes the valve. Not sure if that the way the Suzuki tap works.
Last edit: 7 years 4 months ago by Bucko.
The following user(s) said Thank You: Kawboy, Gunhog63
  • Raygun
  • Raygun's Avatar
  • Premium Member
  • Premium Member
#19756
biltonjim wrote: I recall this topic was covered a while back, and a member of this forum said he had used:
New Suzuki GS450 GS750 GS1100 GS1150 Petcock DIRECT REPLACEMENT ( full ebay description)
This, also, is a vacuum operated tap.
Yup, one like this is what I use on mine and it fit perfectly, used a tee off of one of the vacuum hoses. It has been trouble free since. I'm pretty religious about turning off fuel taps on my other motorcycles, so I felt a vacuum tap was a must for this one.
1982 KZ1300
2003 KLX400SR
1999 KDX220
Wife
Son
Daughter
Cat x 3
Last edit: 7 years 4 months ago by Raygun.
The following user(s) said Thank You: Gunhog63
  • Bucko
  • Bucko's Avatar
#19757
It looks like there's a 'prime' selection on that tap. What does prime do?
  • biltonjim
  • biltonjim's Avatar
#19759
The prime position allows fuel to flow without cranking or running the engine. It is useful if the carb float bowls are empty, eg after a rebuild or lay-up. Switch to prime setting, start the engine, switch tap to “run” setting.
Last edit: 7 years 4 months ago by biltonjim.
The following user(s) said Thank You: Bucko
  • Tonto
  • Tonto's Avatar
#19760
Ive got a couple of bikes fitted with vacuum taps - (as BiltonJim said) I always use the prime facility when the bikes have been stood for a while, to fill the float bowls: works everytime, just wish I had fitted one to my Z13 rather than the Pingel unit.
  • jamesdale44
  • jamesdale44's Avatar
  • New Member
  • New Member
#19761
no your not correct I have one hose and it has worked flawlessly for 10years, you must use the prime on it after setting for some time,but everyday use its fine
Time to create page: 0.177 seconds
